RE: RUN AWAY DAMAGE
Hey Bentley
You may need to change your 3rd channel to run your Kill Swtich. You connect it to your recever & then to the kill switch on the motor. You can then use the 3rd channel to kill motor or if there is a problem with power or if your signal becomes weak or interrupted it will also kill your motor too.
I use TGN Engine Kill Switch.
works great.
