RE: Help with 29CC CY engine...
TOM..I have the same engine I run in my firehammer...your factory default is: 1 & 3/8 turn out High side..1 & 1/4 Low side ...This will get ya started...
after engine is warmed up make very small adjustment to high side first......Do you have a 3 channel TX? Do you have a modified Engine Kill switch yet?
These are the very first things I would do before running the RC Unit......Your Tx Fail safe will not kill the engine..for a run away unit....Just some advice to safe you
some dollars if gets away from you or hurt some body....AKASlwahammer
