RE: wet coil
Is that a new Coil?..You might want to put on a better coil wire...when you do also use heat shrink at the coil to seal it..will
also help from pulling loose....Who knows when that coil wire was made and how long been sitting on a shelf...there subject too
pin holes....Just a thought...You can get a silacone cover for the kill switch...use die-electric grease on all your connectors.........
AKAslawhammer
