RE: T-Maxx Steering servo
Are you using the AA batteries on your truck? if you are? change it for a hump pack battery. I have megatech 1500-mah hump pack and made a big difference on steering the truck, just to let you know I'm using the original servos from 2001.
Is up to you if you still want to go with metal steering servo (witch I recommend) or a less expensive hump pack.
