Hi Paul,
I will be back on her over the weekend John!
Not sure I have much to add to what Paul has pointed out for you. Try and use a shim or two on your main gear mount blocks if needed. Using them helped me get the angles I was after.
Check the length of your main strut ram clevises. You may find that the length of the ram on the right side may need to be different on the left side! I played with the sliding
arm on the main strut till I was happy then marked it where it worked best for me and had it welded. It plays a major part in controlling the forward rake. Just make sure when retracted
it clears the door/frame.
Best,
Ro
