ORIGINAL: bsrman14
ORIGINAL: mooman007uk
If you want the best servo get a rhino digi4 initial 380ozin and .10sec transit, holding is 205ozin, some folk say you need a voltlimiter but as far as I'm aware my spektum 3000 only outputs 6v as does my nomadio transceiver so they wont burn out with no limiter. Maybe other receivers don't limit output voltage like the 2.4ghz ones
Wrong specs. the rihno id 200+ oz and 250 holding.[
] The biggest cheapest servo is the GWS 777 with 470 oz for the price of 2 hs 805. If you want bigger than that a Tone 050 with a wapping 900 @ 6 volts.Orice of 2 hs 7545 seervos.
wrong buddy, the rhino is actually 373 and not 380 (my mistake) initial and 205 holding...look it up, most other servos quote initial for their torque figures. The tonegawa is 600-1800 depending on input voltage but is as slow as a slug unless you get an oddified one. best servo after the rhino is the 5745. the gws 777 has plastic gears which for steering in 1/5 scale is akin to a chocolate fireguard.
