ORIGINAL: rc-martin
Hi All,
Does anybody have an exploded view with part numbers for a CY 260 engine? I'm after a piston and cylinder and the shop I'm using only lists part numbers.
Here is a rebuild instructional build vid and it uses the 23cc CY. (there are actually 9vids)
http://www.youtube.com/watch?v=e0aFZ1ACrsE
It is a very good instructional vid, and you can see the exact parts in very good detail. The even describe what the parts are called so you can type the part name in the link that BadClown gave and you can find the part in that site very easily.
As for exact part numbers and all, you unfortunately would have to do some cross checking: write down the names of the parts as the instructors describe, type them in the search engine in the DDM site, and see waht available PNs come up.
Though this rebuild vid series is only for the 23CC, the rebuild methods are exactly the same. So, for a 26cc, or even a 28.5cc or 30.5cc CY, these vids will give you a very good idea of the parts included in your CY engines.
