RE: Question for Baja Owners
For those of you that are going to do the axle modd
Be careful of clearance issues between the bolt head and the a-arm.
I used 10/32 low head screw and a big steel washer with the flange ground flat to the hubs surface.
Shimmed the outside and put it back together using loctite on the threads.
The head of the bolt just barely clears the a-arm but works sweet!
