RCU Forums - View Single Post - Seagull Gee Bee Z
Thread
Seagull Gee Bee Z
02-01-2009, 04:38 AM
24
0257
RE: Seagull Gee Bee Z
Gee bee ace, your engine 26cc is definitely a right choice. If you really get a wing loading close to 90g/dm you should lend with no problem with an airplane of 180cm of wingspan. Static thrust could be 1:1 to the weight of the aircraft.
What batteries are you going to use? Rx and ignition system?
To keep my gee bee powerfull and as light as possible I decided to use one battery system for both RX and ignition at the same time. I will use TURNIGY 8-15A UBEC for Lipoly (34g) and Li-po ZIPPY 2100mAh 2S3P Receiver Pack (94g) both from Hobbycity.com.
It will give me battery light indicator, safe electronic switch, enough power for servos and ignition. All together weights 128g.
Reply
Like
0257
View Public Profile
Send a private message to 0257
Find More Posts by 0257
View iTrader Profile
