Ok Ok, give me a sec to get the pics of the camera.
(sorry about the bad quality)
Doesn't look THAT different from yesterday.
Made engine mounts for the other side and drilled out the holes so I could put a bolt through it.
It was threaded before.
Also, I've decided that the motor is sticking up too much as it is, so I'm gonna tilt it forward 90 degrees.
And move it down by the thickness of the aluminium tubing, which is about 25mm.
Need to get that weight closer to the ground.
Spent a lot of the day working on the engine mounts and playing around with the gears.
