JETT .46 and FAI Fuel?
I've been floating the idea of mixing my own fuel and going the 0% Nitro route. My current setup is a Sport Jett .46 running with 15% Powermaster fuel. Ground RPM with a 10x6 APC is 16K. Plug is a K&B 1L. If I do change the fuel to 0% what changes should I make to the engine? Do I drop to a 9x7 and try to keep the RPM's around 16K. Also should I remove the two aluminum shims that are already installed on the engine?
Thoughts?
