ORIGINAL: clubin
It will bolt rite up, but if you are going to change the bearings and seals it might not be a bad thing to see how the ports line up, I installed that exact kit on a zenoah. I had to grind some of the case away, so the transfer ports lined up perfect. Not areal big deal though, if you put it on sa stock case you would be just fine.
What I did was with the case split and put the cylinder on one case half and make sure the bolt hole lined up and see how the transfer ports line up to the case. This can be done on each side.
Ok...so you don`t think that the little notch or tap in the top right hand corner of the crankcase will interfer with the the kit in some way? All other corners seem the miss this little notch, what is the purpose of this?
