RE: Hyperion SU 31 Build Suggestions
Jared, if the Hyperion Sukhoi 31 that you have is the same airplane as mine, then you need a much larger ESC, at least 45A or larger depending on your motors Amp draw.
Is your Futaba radio that your Dad sent you a 2.4ghz system? or is it a 72mh? It doesn't matter as long as the Rx has enough channels for the airplane. You need at least 4 channels for the Sukhoi-31. Throttle, Rudder, Aileron, and Elevator.
Jim
