The first problem and probably the most complex to fix is the wing center section.
To simplify construction H9 made a horizontal section between the wing halves which is fine, but it extends out past the side of the fuselage quite a bit.
Like CorsairJock I wanted to fix this, looked at it and nearly gave up after figuring it was too hard and not worth it, but sense prevailed!
I read CJ's thread a few times before doing this and all credit is his. I did it a little different in places though.
There is something very wrong with taking a perfectly good airplane part and ripping off the covering and chopping it up.
But here we go...
Remove the belly pan and rip off the covering... [:'(]
Edit: That plywood plate for the wing bolts is glued on top of the covering... just as well it isnt structural
