RE: Goose's TWM 27% Ultimate assembly
I decided to use the supplied servo horns as they are very stiff GRP and feature a tiny bearing for the clevis hole.
The down side is that the bolt pattern doesn't match any servo horn that I can see, and I tried Hitec, Futaba and JR!
Drilled my own, 4 bolts, Loctite and nylock nuts did the trick. The rest of the mounting hardware is standard Hitec supplied.
More soon...
Goose
