RE: Diamond Dust, Shrikes or Force one
Hay eye:
Ok, go back to that webra 55, get some 10% powermaster or equal, add 2 oz of good castor, change the prop to a apc 10 X 10, add new OS 8 plug. Start, run rich on the ground and turn the thing loose. Bet you will pick up 10-20 mph. Don't know whay that motor wants a lidttle more castor, but I dont try to figure it out. Mine runs like poop on 15% and no castor, different cat at 10 %. Don't think I have ever had a engine unload in the air like this thing, pipe is Jet side mount. If hyou did not break this one in with great care on the bench, you are not going to get the max. performance. Good luck and enjoy.
