RE: ........... BELT CP V2 Thread..........
Other then the erratic tail sway,and swing,it was a better "outa the box" then the CPV3,the transmitter seems a bit sluggish,now Im off on a 5.5mm nutdriver hunt,I only have one,but you need two at the same time to attempt,see the word "attempt" to remove the cross shaft,my thinking is that with the shaft being bent,it may be hard to get the shaft thru the houseing,what I may end up doing is picking the least bent side,cut it off as close to the housing as I can,and try pulling it out that way,but that will be an attempt,we'll see,I''ll get it,or I'll just buy a new head parts bag.................happily,the swash plate for the CPV3 is only $12.00 (see Below)and I love my cameras too.....
