RE: My MaxCat build
Slider46 why did you go with 1/4 inch wood? All you needed was 3/16 th. Not saying you wrong but the weight will hurt a bit. As marcel said his is at 22lbs yours may be 26lbs. What thickness wood you got for the skin? Me i went with 1/8 thick but i'm fiberglassing the hull. So i dont have any problems with splits. How do you plan on sealing the hull?
