A small rate gyro is all you need if you feel you need to tame a hard to handle plane on the ground.
You don't have to worry about in-flight adjustments and the stick will over ride the gyro input for normal flying.
Set it for 50% and adjust if needed.
http://www2.towerhobbies.com/cgi-bin...?&I=LXL313&P=7
