Gyro Use...........
if the plane is squirly on the ground, then yes, a rate gyro is a good choice. but if you have a big prop, or something or other with a lot of torque, than it will constantly want to move, so you micht want to get one with heading hold as well. it also will compensate for the difference in sensitivity between the rudder and tailwheel.
