Gyro Use...........
OK everything is very intresting. Now Here are a few questrions. First is there any other gyro other than the original futaba that would work as well and at the same time have the option to be turned on and off on the remote (I have a 9C ) ?
Second I went to tower hobbies site and saw that there are a loto of gyros (futaba) some of wich cost a fortune, digital display and all, now they say "for heli" and others for planes, what is the diffrence and would this last one work in a plane as well???
What is the SMM tecnology that some have ??
Last question is that I can see two airplane gyros the
Futaba GYA351 Gyro Aircraft Dual Servo the other is
Futaba GYA352 Gyro Dual Axis Aircraft
now is that what I think, one is for example for the rudder, in case I had 2 servos on it and the other one is for two diffrent corrections, lets say ruder and alerons??? And in case I put a gyro on a control surface will it work only when the control sticks are at center or even during manuvers... If they do work always wont that affect my handling possibilities???
