tmaxx .21 conversion problem
ok,first thank all of you for youre help,second,none of this has worked,i tried the way traxxas says to check the one way bearing, "hold the shaft sticking out of the transmission w/ pliers,and spin the spurgear both ways",if it is still good,it should spin one way,and not the other,and it spins one way,and it willl make that shaft that youre holding w/ the pliers spin, so not the problem.then,the idea of loosen the adjustment screw on the forward gear "black ring" nothing changed.NO POWER COMES OUT OF THE TRANSMISSION,PLEASE HELP
