ORIGINAL: afterhours
So the motor/prop combos you tried won't work. Can you kindly explain further?
Jared, With the numbers that you supplied for the TR 35-36B. The Motor calc said that the normal sized props are pulling too many AMPS. I think that the numbers are wrong. Like I said in the previous post, the best way to determine what your set-up should be is to hook it up to a watt meter. You can also go ahead and fly your set-up without testing for AMP draw, but you take a chance of burning up a ESC and Or your motor. As long as you are running a seperate BEC or receiver pack for the Rx and Servos, you will still have control of the airplane.
Jim
