Old 03-01-2009, 06:51 PM
Pattern One
My Feedback: (73)
Pattern One's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Mach 1 Laser Kit Build
I have decided to use the Hayes 16 oz slim line tank as I think this will work with some a little top block hollowing. I sent Dan the fuel tank measurements and he cut F2 so the tank can be inserted from the wing opening. I did some initial assembly of the crutch and formers and as you can see everything fits dead on so far! Will post more as things move along.
While I am building the fuse Dan is working on a built up wing and stab. Dan said the built up wing will be designed to be interchnageable with the foam wing and will have provisions for retracts. Dan intends to put build tabs, wing jigs holes and servo extension holes in the wing ribs. I plan to do both a foam and built up wings as part of this thread.
ID:	1148011   Click image for larger version
ID:	1148012   Click image for larger version
Pattern One is offline
