Old 03-04-2009, 06:36 PM
DougC1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Mach 1 Laser Kit Build
Couple of questions if I may.
1) Am I correct in seeing that the entire fuselage is aligned by its’ top/crutch, and the fact that the fuse formers are set square/perpendicular? I’m assuming the top of the fuse sides are straight from about the wings leading edge to the stab leading edge. Assembly requires no strings, or lines on the building board?
2) What did you use for adhesive between the ply doublers and the balsa fuse sides? I’ve had to do some fancy stepping at times when using any water based glue.
3) Is that “nose section” gonna drop right in the front? Just to cool.
Looks good thus far; pleased to see that the beta working out.
Doug
DougC1 is offline
