The recommended Center of Gravity (CG) location for
the P-47 is 6 1/8" behind the leading edge of the wing
against the fuselage. Make sure the gear is retracted when
checking the CG, as the CG will change depending on
the gear position.
Heres a link to it online
http://www.modelflight.com.au/manual...P47_Manual.pdf
