are you sure that your friend has the 1st gen maxx and not the new maxx
I fixed my problem... by accident doh.
I was just messing around to see if my wires were going in the little slot that is cut in the casing to the part that holds your batteries and it went into reverse. then it went back in the middle. So I played with the wires to find that the wire going to the servo to switch forward to reverse had to be real tight for some reason. So I just pulled it down around another servo so its tight and everything works fine. Sry if there are many errors but its 3a.m. here and im tired
