Old 03-10-2009, 01:37 PM
Pattern One
My Feedback: (73)
Pattern One's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Mach 1 Laser Kit Build
Hi guys,
Pictures of Laser Technologies prototype built up Mach 1 wing attached. The parts fit so well that you can pickup the wing panel and move it around with hand. Note the building tabs and wing jig holes on the ribs. Retract mounting provided. I should have the production BETA built up wing to start tomorrow or the next day. The built up wing has the same airfoil as the foam wing. You can see a balsa piece has been added out near the trailing edge tip to provide some strength and tie everything together. The wing also features a built in dihedral brace so you can build one panel flat on the board, then put the other side down on the board to complete the build. Dan will be offering both built up and foam wing options with his short kit. More to follow.
Leo, aka glockguy
ID:	1154510   Click image for larger version
ID:	1154511   Click image for larger version
ID:	1154512   Click image for larger version
Pattern One is offline
