Hi All,
Need to ask for opinions here. I purchased a glass cowl and pants from Stans FiberTech for my Extra 300s. My situation is I also purchased a can of auto primer from Napa Auto Parts and unsure if it is ok to use on glass. It is Dupli - Color Gray Primer called Engine Enamel with Ceramic. It is heat tested and fuel proof.
With the Info I have given above do you think it would be safe for the Fiberglass?
There is no suggested uses on the can except metal objects, but the guy there said it is heat tested and definitely fuel proof and should be ok for Fiberglass.
Thanks for your opinions much in advance.
