Old 03-22-2009, 08:24 PM
  #254
butlern
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Charlie Kellogg's TBM Avenger Build
When that was all figured out, the motor and F-0 was set aside and then I moved on to the tail wheel.
The tail unit was bolted to some hardwood, and the hardwood was then installed into F-14. In order to get the wheel to fully retract (or at least come very close to making it all the way into the fuse when retracted), I had to mount the tail wheel to F-14 at a bit of an angle. F-14 was basically notched and the hardwood and some additional plywood was glued together with methacrylate.
I posted a question in the general forum regarding steering the Sierra tail wheel units. This one is especially tricky, I think. I'm not really seeing a clear and obvious method for actuating the steering. I was planning to use cable and guides, but there’s such a large “drop” (down out of the fuse) down to the steering yoke that I’m not sure how or where I am going to place the cable guides.
If anyone has any suggestions, please let me know (ASAP as I have to sort all that out before I start sheeting the fuse).
ID:	1163730   Click image for larger version
ID:	1163731   Click image for larger version
ID:	1163732   Click image for larger version
butlern is offline
