StingRay,
Try leaning it out a bit by turning in the HSN after the egine is at temp! If it is loading up it is running too rich and needs to be leaned a bit! You can also turn in your idle screw in a bit to keep it running while you are tunning it and after you get a good tune you can set a good idle!
