Originally posted by Capt G
You can almost see it in the picture but it's only about 2 degrees off vertical. Where did you find 4/40 rods long enough to reach the tail? The only other change I made to the hardware was to use Robart BB control horns on all surfaces.
48" 4-40 rods at ONE of my LHS- Grave's RC Hobby in Orlando, FL.
I've found my worst dislike of the plane- the rudder horn attachment. There's no hardwood, and the rudder is so fat, you can't use bolts- threaded rod and nuts??!! Yuk!!
- George
