RE: best glow plug for TT pro 40
RedFox,
I understand the temp range vs the RPMs. I gave the data of high RPMs to allow the information out that I am running a high RPM which creates the higher temp range. If I was at a lower RPM I wouldve listed that, but High RPM's run constantly is to be configured into the plug selection because it effects the temps. I guess I wasnt clear enough on that. Thanks for the input however!!
