Savage Throttle/Brake Linkage
You should adjust the servo saver so that throttle operation is optimized. The brakes are more easily adjusted.
You can replace the tubing on the brake linkage with a longer piece if you need more grab. Also you can loosen the set screw and drop the brake linkage arm (the vertical piece) a few mm or more. Be careful though you don't want too much...it will flip over real easy.
