RE: Is HHO gas can run RC engine
I would start by changing the engine... the first problem and a big one, is that for a nitro engine to stay running, the platinum in the coil needs to react with the alcohol in the fuel to keep the glow plug wire glowing.... problem #2, and maybe a bigger one is lubrication... lubrication for a 2 stroke comes in with the fuel, and if that fuel is a gas... no lube.... Cant be done. end of story.
