RE: eeekks ... hope this don't happen!!
I never use a primer. TOO soft when dry.
I put on any large color area.
Let it dry ....UNTIL...you DO NOT SMELL ANY odor when you SLIGHTLY heat the paint in a 140 to 160 F oven................ NO odor. It is dry & is ready for a masking tape job.
I am a Electrican. So I mask everything with the stretchy black Vynyl tape. It is a great tape as it is stretchy and VERY FLAT, EDGE TO THE EDGE!!!!!!!!.
I peel it off at a very steep angle. I am dragging the removed piece over the part still stuck down...ALWAYS pull any tape off WAY,WAY before it is too dry!!!!!!!!!!!!!! Damp is fine.
I have never tried using 2 or more coats on the tape & then pulling it up.
