ORIGINAL: vicman
I think the reason a lot of them end up smucked is because they are overpowered and flown irresponsibly at high speeds close to the ground by adrenaline-wacked Revver Brethren.
Wha the hey... You better sleep with one eye open there Maple leaf boy![X(]
Your MAAC card will get you in the door at our Speed Rally
Shows what they know. But that is good news, thanks very much for checking!
This here combination is getting more than passing consideration. Looks silly, but the airframe and engine package as you see weigh only a little over 3 pounds so far. It should be possible to have AUW at 5lb or so which will be very manageable. The model is a Ukraine made composite FAI lekkie model, a few years out of date for that purpose. The thing is a work of art. It will be a shame to spray it with castor oil and then belly land it at 40mph. But talk aboot a quick way to make a new putt-putt for June, to replace the defunct Whip project.
MJD
