RE: Aurora 9 radio
Hi,
Can you tell me if:
1. The Aurora software will allow you to select Mode 1, 2, 3, or 4?
2. Also, I'm assuming you would have to by each transmitter frequency module seperately that you will need, example 72mhz and 2.4ghz, is this correct?
3. If the transmitter has a 72mhz module, will the transmitter allow you to select positive and negative shift in the software, that is, would it be compatible with JR, Futaba, Airtronics and Hitec standard receivers?
Thanks for your help.
Fly4Fun,
Wayne Miller
