RE: Ed Kazmurski's Taurus
Yes Cees, is a bit strange, but that was clear before. It's clear what you wanted to say with your picture in #1235. But if we assume the distance between the formers is only 12.5" (standard) and since we know the root chord of the standard wing is 11,7" including bellcrank tubes and that of the swept wing is 12" or even 12,2", then there is simply not enough room to shift the wing 1" only forward. It has to "grow" forward and backward. 1" forward would require moving the former, that's all.
