Old 04-12-2009, 08:01 AM
Bob Pastorello
My Feedback: (198)
Bob Pastorello's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Newbie to Gas General Information
17. Mufflers - nearly all of them are NOT; they are exhaust cans with diverter outlet tubes. They are usually louder than you think. If you want quiet, you need a canister, period. Not necessarily for newbies.
18. Install muffers with no gasket, use a thin film of Permatex High Temp Permagasket on the face of the muffler flange. Put RED "permanent" or "high temp" Loctite on the screws, and tighten them. Tightly.
19. If you have to use a Pitts muffler, brace the canister part to the engine/firewall with a bracket or strap of some kind. Tighten the muffler to the engine exhaust THEN install the strap/canister attachment. Don't do it the other way.
20. Smoke is not for a newbie. If you must smoke, get help with it, as you've instantly doubled your plumbing complexity, tanks, added weight, electronics, etc. If you have to have it, post here on "How to Setup Smoke". It works great and looks like a million $$$ but most folks don't mess with the mess.
21. Spark plugs. These are not glow plugs. They need ignition sources. They have to be properly gapped. They should not be oily-looking, fouled, or have shiny metal flakes on the porcelain. ANY of these things are symptoms that something else is wrong.
22. If your engine doesn't "take throttle" (hesitates), the low end is probably lean. If it "takes throttle", but bogs down, coughs, sputters, etc. it is low end RICH. NO doubt about these. Properly-adjusted gasser carbs operate very well. Poorly adjusted ones will make you insane.
23. If you have been flipping until your arm is ready to fall off.....go back to the first post on this thread. SOMETHING ain't right. All of these engines need air, gas, compression, and ignition. Given all of them in the proper portion and time, these engines ALWAYS start. If they do not....SOMETHING IS NOT RIGHT!!!!!! Don't post on RCU about what to do.....figure out what's missing from the thing. If it's all there, THEN post for help. We will be happy to help....those who try.
Bob Pastorello is offline
