RE: Newbie to Gas General Information
For those following this thread....as new things occur to me, I'm going back and editing my previous posts where the item logically fits.
I'll add new posts as new items occur.
31. When you have a new engine....buy a new (correct) spark plug. And as soon as you can afford it a Spare Ignition, and a Hall Sensor/switch. Spare carb if you aren't a "carb tweaker". Carb rebuild kit whether you are or are not. Buy replacement prop bolts, and be sure to use split and flat washers so the prop washer doesn't get all boogered up. Many manufacturers don't know about this yet, so they don't include screws long enough for thick hubs and spinner backplates, much less the split and flat washer. It is worth investing in.
32. Buy extra metric screws and ball drivers. NEVER trick yourself into believing that a 10-32 is the same as a 5mm. They ain't.
