Stupid Question
Trying to pull the pin out with pliers (correct spelling) is never the correct way. Even if you are successful with that method, the piers will leave grip or "dig" marks in the pin. The proper method is to use a drift punch, the same diameter as the pin, to gently tap out the pin.
