OS carb for .26
I am looking into replacing the carb on the Picco .26 with an OS carb because the picco carb is a real pain to tune. I have already replaced the LSN with the new one and changed all the orings on both the LSN and HSN. The engine is running much better but still a bit on the hot side. I think I am still getting a airleak on the HSN but that's another story.
I would like to know if there is a OS carb that will fit the .26? I have heard that OS carbs are high quality and hold a tune really well.
If someone knows of any informations on which carb would drop in I would like to know, as well as, the part number.
I checked some other sites and I know OS has both composite carbs and an aluminum carb. I would think the composite carb would be better?
Also, the carb on the picco has a 8mm insert so I would like to keep it the same.
