VIPER TRIM ISSUE:
Hi guys,
Got another one to run by you's.
While trimmed to fly straingt and level I end up with the following trims on the plane.
*** 12 Clicks of Left Aileron
*** 5-6 Clicks of Up Elevator
Now the Plane is a Viper and it is set up with 0-degrees across the board. It pulls a bit to the right and down, therefore the above trim. The lateral balance is OK and I'm at 2-3/4" C.G. When flying the course it seems to turn 1 nice and straight and level and goes where you put it. Why? Why would she pull down? Nose heavey , I don't think so in fact I just moved the CG back from 2-1/2". Down trust, it's at zero but even if there was a 1/2 a deg or so, most planes have a little (oe are all bets of because of the type of plane it is). I would not think it would make that much difference or could it? Rolling to the Right? Engine Torque? I am trying to get it to fly absolutely straight and level with all trims as neutral as possible to loose the drag. Any sugeestions. You guys have been awsome before!
Ed
