Wrap it up and make sure it is in the right direction to pull the starter string in! When you wrap it up or coil it you take the outside end and pull it to tighten the coil and then coil up the extra spring that you pulled and you my have to do this a few times to get it tight enough! Keep in mind that it is kind of hard to hold on to that spring sometimes and try keep it away from your eyes because it is pretty sharp!
Before you do the above rewind the string or it is hard to hold that tightly coiled spring and rewind the string at the same time!LOL I know I tried to do it before!
Anyway that should be all you need to know in order to get the job done!
