ORIGINAL: mikewait
Alright i don't think i will get rid of the dual rudder or the trim tabs...
also the m6 can't have a clutch so i don't like that idea...
Looks like im stuck with the m5
Unless i send in my m5 and get it even more modified
http://bonzisports.com/mods.html
If i had the bzx2 or bzx4 how fast would my boat go if i trimmed it right??? and maybe changed the prop...
Also any prop recommendations???
I realy can not comment on bonzi engines as I have never seen one running at our lake. But I still think the limiting factor is the hull design not the power plant. When we setup ours on the "way" loose side we been have been able to run in the low 40's it is just not as much fun when it spends more time in the air than on the water. BTW the M6 can be used with a clutch, it just will not be as fast with it on.
