John,
Indeed, you can not operate the valve via the RX without air pressure in the system above the gear failsafe setting (default is 50 psi). The manual button will override the valve and follow the programed sequence even without air but, without air driving the gear, not much to see
Let me know if you have any additional questions once you have the valve fully installed....
Regards,
Todd
