RE: Bob Cat Copy Falcon 120 Jet
Hi all,
great to read your building tips and to share your enjoyment of flying this great whoosh plane, i rarely have much to say especially over the last month as i have re-test flew my eurosport and the following 9 flights-all good
i have only been flying a handfull(well nearly 2 handfulls-but time passes so quickly) of years and have only built(i know atrf prop plane stuff is not building) about 3 planes,so building tips from me are few and far between but 1 that may be of help-
re battery in rear to balance,i cut a hole in the side of my fuz behind the rear spar and fed the 4.8volt sub c in,packed the battery and the hole with foam and lightly tacked the hatch back in place-it can not fall out or be seen once the wing is on.
i wish i had got into this hobby years ago but then agian i probably wouldnt of got any money left by now at the rate these jets keep ringing up the ££££££££.
happy flying all
mark
