power issue?
thought i had a power problem with my battery but i tested it and everything is ok.
today i setup as normal and had a fly about for anout 3 mins, low level.
power cut, i was only about 5 inchs off the ground so no damage.
no leds on. iv cchanged the fuse too.
i turned it all off and back, all ok. but when i apply throttle the power cuts and leds go out, then the leds return on after about 5 sec's.
it does this every time. tested battery again - all was ok.
what could be the prob?
