RE: New Viper 500 RTC
Scott,
Thanks for the info.
What I do on the firewall is cut a piece of 1/4" plywood and fit it inside the existing firewall. Then pin the new firewall. Hopefully the RTC doesn't have glass on the inside of the tank area.
I have a unused Viper fuselage that has perfect incidences. I have decided to strip it and make a plug out of it. The new plane will be called the CopperRattleHead. I will keep the price as low as possible. The tail will be glued in. I will probably do a composite tail and the linkages will be internal on the composite tail. So with my composite Viper wing, an all molded composite Viper will be available.
